Introducing Automox Turnkey Results
Automation only works when policies are designed correctly. Turnkey makes sure that happens.
With Turnkey, you get a Blueprint tailored to your goals and proven to work across millions of devices managed by Automox. It defines which policies to run, their automated schedule, how endpoints are grouped, and how success is measured and maintained.
This blueprint removes guesswork, eliminates reliance on tribal knowledge, and lowers configuration risk owned solely by you – the IT and security team.
When you manage endpoints with Turnkey, automation becomes repeatable, defensible, and stable.
What is Turnkey Results?
Turnkey Results is an Automox solution that provides a Turnkey Blueprint designed to deliver specific security and operational outcomes.
Each blueprint is:
  • Built on Automox best practices
  • Aligned to common customer security goals
  • Designed for your specific environment
  • Implemented by Automox on your behalf (optional)
This approach removes the burden of designing, testing, and deploying complex patching and configuration strategies internally.
Key Benefits
Faster Time-to-Value
Turnkey Results accelerates your path to improved security outcomes by removing the need for internal design and trial-and-error. Automox delivers an implementation aligned to proven best practices from day one.
Expert-Led Implementation
Automox designs and implements your environment, ensuring the solution aligns with platform capabilities, security standards, and your stated goals.
Reduced Operational Overhead
Because Automox manages the initial implementation, your team spends less time building and maintaining patching logic and more time focusing on strategic initiatives.
Outcomes Aligned to Best Practices
Turnkey Results is designed to deliver measurable outcomes aligned to Automox best practices and real-world customer needs, helping ensure consistency and reliability across your environment.
Common Use Cases
Turnkey Results is ideal for organizations that want to:
  • Improve patch compliance quickly
  • Reduce risk from unpatched vulnerabilities
  • Align patching and configuration practices to Automox best practices
  • Accelerate security outcomes without building solutions internally
Who Should Use Turnkey Results
This solution is well suited for:
  • Security and IT teams seeking faster outcomes with less effort
  • Organizations that want expert guidance without custom development
  • Teams looking to mature their patch management strategy efficiently
Getting Started
Turnkey Results is delivered as part of the Automox platform and includes Automox-led design and implementation based on your environment and goals.
If you want to learn whether Turnkey Results is the right fit for your environment or have questions about availability, reach out to the Automox Sales team for guidance.
