Device is showing as "Not Compatible"
Pretty self-explanatory. You have a device that is showing as "Not Compatible". There is one easy method to check for why this is the case.
How to Check
- Find the Device that is showing as "Not Compatible". Open its Device Details page, and scroll down to the Troubleshooting section.
- Find the Review Checklist button and click it to open a list of what's wrong. It could be multiple issues, but generally the Checklist will try to provide you with as many details as possible:
(Different Examples)
