Objective
To provide an Automox Worklet that remotely modifies the Windows Cached Logons Count registry setting (CachedLogonsCount), allowing administrators to reduce or disable cached domain credential logons on off-network or terminated user endpoints.
Overview
Windows caches previous domain logon credentials locally so users can log in when the endpoint cannot establish a connection to an Active Directory Domain Controller.
In security scenarios—such as offboarding a terminated remote employee or hardening isolated devices—administrators may need to set CachedLogonsCount to 0 (or another specified threshold) to prevent unauthorized local logons using stale domain credentials.
Use Cases
  • Remote Employee Offboarding: Immediately prevent a terminated user from logging into an off-network laptop using cached domain credentials.
  • Security Hardening & Compliance: Enforce organizational security policies that restrict or disable cached interactive logons on sensitive endpoints.
Worklet Setup Instructions
1.Create a New Windows Worklet:
  1. In the Automox console, navigate to Policies > Create Policy.
  2. Select Worklet and set the OS target to Windows.
  3. Enter a descriptive policy name (e.g., Windows - Set Cached Domain Logons Count to 0).
2.Configure Evaluation Code:
Paste the following PowerShell script into the Evaluation Code block. This script checks the current registry value and returns 0 if compliant or 1 if remediation is required:
PowerShell
# Automox Worklet Evaluation Code: Cached Logons Count
$scriptblock = {
    $regPath = "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
    $regProperty = "CachedLogonsCount"
    $desiredValue = "0"
    # Retrieve current value for comparison
    $currentValue = (Get-ItemProperty -Path $regPath -Name $regProperty -ErrorAction SilentlyContinue).$regProperty
    # Exit 0 if compliant, Exit 1 if remediation needed
    if ($currentValue -eq $desiredValue) {
    } else {
        exit 1
# Execute in 64-bit PowerShell context
& "$env:SystemRoot\sysnative\WindowsPowerShell\v1.0\powershell.exe" -ExecutionPolicy Bypass -WindowStyle Hidden -NoProfile -NonInteractive -Command $scriptblock
3.Configure Remediation Code:
Paste the following PowerShell script into the Remediation Code block to update the registry key to your desired value:
PowerShell
# Automox Worklet Remediation Code: Set Cached Logons Count
$scriptblock = {
    $desiredValue = "0"
    try {
        Set-ItemProperty -Path $regPath -Name $regProperty -Value $desiredValue -ErrorAction Stop
        Write-Output "Successfully updated $regProperty to $desiredValue"
    } catch {
        Write-Error "Unable to update $regProperty: $_"
        exit 1
4.Assign Device Groups & Execute:
Assign the Worklet policy to your target Windows Device Groups and run the policy manually or on a scheduled cycle.
Key Operational Considerations
  • 64-bit Execution Wrapper: The code uses $env:SystemRoot\sysnative\... to ensure the registry modification occurs within the native 64-bit registry hive (HKLM:\SOFTWARE\...) rather than being redirected to the 32-bit WOW6432Node path.
  • Default Windows Value: The default Windows value for CachedLogonsCount is typically 10 (or 2 on older systems). Setting this value to 0 disables cached domain logons entirely.
