How am I am able to secure my endpoints from this latest Zero-Day vulnerability?
We have more information on our blog here: https://www.automox.com/blog/follina-zero-day
Answer
No patch has been released yet. Microsoft has released a temporary workaround which we recommend applying in the interim until patches are released.
The Automox team has created PowerShell scripts you can use in a Worklet to apply the temporary workaround to your Windows estate. These are based on the recommended workaround steps from Microsoft.
Worklet Evaluation Code to Remove Registry Key:
################ BEGIN MAIN CODE ################
# Mount HKey_Classes_Root as drive
New-PSDrive -PSProvider Registry -Name HKCR -Root HKEY_CLASSES_ROOT | Out-Null
# Tests for HKCR:\ms-msdt
if(Test-Path -Path "HKCR:\ms-msdt")
# Key found triggering remediation
Remove-PSDrive HKCR
Exit 1
# Key not found, no remediation needed
Remove-PSDrive HKCR
Exit 0
Worklet Remediation Code to Remove Registry Key:
# Variable used to specify export location of regkey. Directory will be created if not present
$regExportdir = "C:\regExport"
# Detect if export dir exists and creates if needed
if(!(Test-Path $regExportdir))
New-Item -Path $regExportdir -ItemType Directory | Out-Null
# Create arguments for Reg
$regArgs = 'export HKCR\ms-msdt ' + "$regExportdir" + '\ms-msdt.reg /y'
# Exports HKCR:\ms-msdt to the $regExportdir
Start-Process -filepath "$env:Windir\system32\reg.exe" -ArgumentList "$regArgs" -Wait
# Deletes HKCR:\ms-cxh"
Start-Process -filepath "$env:Windir\system32\reg.exe" -ArgumentList "delete HKCR\ms-msdt /f" -Wait
# Validation
Write-Output "Failed to delete registry key"
Remove-PSDrive HKCR
exit 5
Write-Output "Successfully Exported Key to $regExportdir"
Remove-PSDrive HKCR
Exit 0
Write-Output "ms-msdt key is not present on this device"
Remove-PSDrive HKCR
Exit 0
Once patches have been released and you’ve applied them, you can undo the workaround with the following Worklet:
Worklet Evaluation Code to Import/Add Registry Key:
if(!(Test-Path -Path "HKCR:\ms-msdt"))
# Key not found triggering remediation
Remove-PSDrive HKCR
Exit 1
# Key found, no remediation needed
Remove-PSDrive HKCR
Exit 0
Worklet Remediation Code to Import/Add Registry Key:
# Variable used to specify previous export location of regkey. Script will cancel if not present
if(!(Test-Path "$regExportdir\ms-msdt.reg"))
Write-Output "Exported regkey is not present. Cancelling..."
Exit 0
$regArgs = 'import ' + "$regExportdir" + '\ms-msdt.reg'
# Import ms-msdt.reg to the $regExportdir
# Validation
Write-Output "Failed to import registry key"
Remove-PSDrive HKCR
exit 5
Write-Output "Successfully imported Key."
Remove-PSDrive HKCR
Exit 0
Write-Output "Key is already present on this device"
Remove-PSDrive HKCR
Exit 0
