How to Test a PowerShell Script Locally for Worklets
Run a PowerShell script locally for Worklets with Automox parameters
When testing a PowerShell script on a local device, running it with the same parameters that Automox uses will help validate the script for worklet use. Automox uses 32-bit and runs as the System account.
Requirements
  • Download PsTools from Microsoft:
  • Use psexec to run as the local System account:
    psexec -s SCRIPT_GOES_HERE
    • psexec requires that an End-User License Agreement be accepted on first use. This can be done with the following command:
      psexec -accepteula
  • When testing scripts, ensure that you are running the 32-bit version of PowerShell with either:
    • Windows PowerShell (x86)
    • Windows PowerShell ISE (x86)
