How to View Bash History
Bash keeps a record of commands entered in interactive shell sessions. On an Automox-managed Linux device this is most useful for establishing what a person did on the box, which is often what you need in order to rule the agent in or out when something changed unexpectedly.
Viewing history interactively
History is per user, so switch to the account whose history you want to see before running these.
Show the recorded history, which defaults to the last 500 commands:
history
Page through it:
history | less
Show just the last ten commands:
history | tail
Show the last 25 commands:
history 25
Each entry is numbered, and a command can be re-run by its number. Given entry 30 ls, run it again with:
!30
Reading the history file directly
History is also stored on disk in the user's home directory, which is how you read it without logging in as that user:
sudo cat /root/.bash_history sudo cat /home/USERNAME/.bash_history
Two caveats when reading the file:
- It is written when the shell exits. Commands from a session that is still open may not be in the file yet, so a live session's activity can be missing.
It records commands, not outcomes or timestamps. Unless
HISTTIMEFORMATis configured on the device, there is nothing in the file to tell you when a command ran, which limits how far it gets you in a timeline.
Reading history through a Worklet
This is where most attempts go wrong. history is a shell builtin that reads the history of the current interactive shell. A Worklet runs non-interactively, so calling history from a Worklet returns nothing and looks like an empty result rather than an error.
To collect history from a Worklet, read the files instead:
#!/bin/bash
for f in /root/.bash_history /home/*/.bash_history; do
if [ -f "$f" ]; then
echo "===== $f ====="
tail -n 50 "$f"
fi
doneBound the output with tail rather than printing whole files, so the Activity Log stays readable.
Bash history is not where agent activity is recorded
If you are trying to establish what Automox did on a device, bash history is the wrong place to look. The agent executes commands directly rather than through an interactive login shell, so its activity is generally not written to .bash_history. An empty or unrelated history does not mean the agent was inactive.
For agent activity, use the agent's own log and the console:
/var/log/amagent/amagent.logon the device - Retrieving Automox Agent logs, to collect it without working on the endpoint
- Display the amagent.log in the Activity Log for Linux and macOS
- The policy Activity Log in the console, for what a policy run actually executed and returned
Used together, these answer the question people usually have: the agent log and Activity Log show what Automox did, and bash history shows what someone did by hand.
