Configuring a SentinelOne Exception for Automox
NOTE: With Sentinel Agent 25.1, this exclusion should no longer be necessary.
This guide provides instructions for configuring an exception in SentinelOne to resolve potential conflicts with Automox. Follow the steps below to add the exception and address related issues.
1. Add SentinelOne Path Exclusion [New Exclusions Experience]
  1. Open the SentinelOne Management Console:
    • Log in to your SentinelOne console with an account that has the necessary permissions.
  2. Navigate to the Exclusions Menu:
    • Go to Policy Settings or Global Settings (depending on your configuration).
    • Select the appropriate group or device policy where you want to apply the exclusion.
  3. Create the Exclusion:
    1. Select Exclusion Type of Agent Interoperability
    2. Set the Operating System to Windows
    3. Click 'Continue'
  4. Add the Exclusion Path:
    \Device\HarddiskVolume*\Program Files (x86)\Automox\
    • Include Subfolders: Yes
    • Apply to child processes: Yes
    • Exclusion Mode: Interoperability
  5. Save the Configuration:
      • Save your changes and allow approximately 5 minutes for the exclusion to propagate.
      • Restart the amagent service or the device for the exclusion to be applied.
      • Verify whether Automox is functioning correctly by scanning the device.
If there are still issues with processes being blocked, try setting the Exclusions Mode to Performance Focus - extended
2. Add SentinelOne Path Exclusion [Legacy Exclusions Experience]
Ensure you're on the Legacy Exclusions Experience (found in My User) when creating the exclusion
To configure a Legacy SentinelOne exception for Automox, follow these steps:
  3. Add the Exclusion:
    • Exclusion Type: Path exclusion for both alerts and mitigations.
    • Exclusion Mode: Interoperability - extended.
  4. Save the Configuration:
  5. Reboot and Test:
3. Alternative Solution: Change Automox Script Execution Directory
If adding exceptions does not resolve the issue, consider changing the Automox script execution directory to a location with permissions for file creation. Follow these steps:
  1. Identify a New Directory:
A commonly used location is: C:\ProgramData\amagent\
  1. Reconfigure Automox:
  2. Test and Verify:
    • Ensure Automox scripts execute successfully in the new directory.
3. Verifying and Troubleshooting
After completing the above steps, confirm that the Automox agent is functioning as expected. If issues persist, consider the following:
  • Double-check that the exclusion paths are correct.
  • Verify that SentinelOne policies are syncing correctly with endpoints.
  • Contact Automox or SentinelOne support for further assistance.
Things to Remember
  • Ensure you have administrative privileges before making these changes.
  • Refer to your organization’s IT policies before uninstalling or modifying security software.
1 out of 2 found this helpful
