How to fix devices that are missing from the Dashboard
Issue Summary
Devices may appear missing or disconnected in the Automox console if the --deregister command has been executed. This action removes the local access key, preventing the agent from authenticating with the platform.
Diagnosis
To confirm if a missing access key is the root cause, check the local agent logs:
  1. Navigate to: C:\ProgramData\amagent\amagent.log
  2. Search the log file for the following strings:
    • access key is missing or invalid
This can also be easily done with the following Powershell command (running as Administrator):
(Select-String -Path "C:\ProgramData\amagent\amagent.log" -Pattern "access key is missing or invalid" -CaseSensitive:$false | Select-Object -Last 1).Line
If these entries are present and recent, proceed to the resolution steps below.
Resolution
You can restore connectivity by manually resetting the access key via PowerShell.
[!IMPORTANT] You will need your organization's unique Access Key found in the Automox Console under Settings > Keys. Note that Access Keys are Organization Specific.
Step-by-Step Instructions
  1. Open PowerShell:
    • Launch an Administrative PowerShell prompt.
  2. Stop the amagent Service in services.msc or with the following command:
    net stop amagent
  3. Set the New Access Key:
    Replace YOURACCESSKEYHERE with your Automox Access Key and run the following command:
    & "C:\Program Files (x86)\Automox\amagent.exe" --setkey YOURACCESSKEYHERE
  4. Start the amagent Service in services.msc or with the following command:
    net start amagent
This can be executed in a single script:
net stop amagent
net start amagent
Related Articles
