Managing Automox Agent Upgrades
Overview
This guide explains how you can manage automatic agent upgrades for your devices, as well as manage the agent release channel your devices are on (Stable / Beta).
Agent Settings
Navigate to the settings drop-down menu in the top-right corner and select Agent from the drop-down
Here, there are three different sections that you can view and manage.
Agent Configurations
Number of Devices: Displays the total number of devices currently running the agent.
Latest Agent Version: Refers to the latest stable version of the agent
Agent Updates
Toggle this option on to enable your agents to automatically upgrade when new versions are released.
Agent Release Channel
Select the preferred release channel for agent updates:
  • Beta: Provides early access to upcoming features with potentiol for minor issues or changes based on feedback.
  • Stable: Delivers thoroughly tested updates focused on reliablility and performance.
The selected release channel will take effect with the next agent update cycle.
