I receive an “invalid action, connection unauthorized” error when setting up AVR
Details
When you encounter the "invalid action, connection unauthorized" error in AVR, it indicates that there is an issue with the API key or region settings used in the connection configuration. This error typically arises when the API key or region does not match the expected values for the Rapid7 Platform organization you are trying to connect to. Here are the steps to resolve this issue:
Create a New Connection:
  1. Go to the AVR connections settings in your Automox console.
  2. Create a new connection by providing the correct API key and region information. Ensure that these details are accurate and correspond to your Rapid7 Platform organization.
Verify API Key and Region:
  1. Double-check the API key to ensure it is valid and has not expired.
  2. Confirm that the region selected matches the region of your Rapid7 Platform organization.
By following these steps, you should be able to resolve the "invalid action connection unauthorized" error and establish a successful connection with the Rapid7 Platform for AVR operations
