How Long is the Patching Window for an Automox Policy?
Objective
To explain how policy execution timing operates in Automox and outline the retry limits for failed patch installations.
Overview
Automox policies do not enforce a fixed or hardcoded "patching window" duration. Instead, policies run dynamically until all queued operations complete or return an error state.
Policy Execution Timing & Retry Behavior
Feature / AttributeOperational Behavior
Execution StartTriggers automatically at the scheduled time configured within the policy settings (or immediately when manually executed via Run Policy Now).
Execution WindowNo fixed time limit. Policy execution continues until the OS package manager completes installing all applicable updates, after which the status (Success or Failure) is reported to the Activity Log.
Per-Run RetriesDuring a single policy run, the Automox Agent attempts to install each individual patch up to three (3) times before marking the patch installation as failed.
Subsequent AttemptsIf a patch fails all 3 installation attempts during a run, execution stops for that package. Automox will re-attempt installation during the next scheduled policy run.
