Issue
You marked a software title as Ignored on a device (from the Software page or Device Details) to stop it from being patched, but a patch policy still updated it on the next run.
Environment
- Automox (current agent release)
- Windows, macOS, and Linux devices
- Console areas: Software page, device Device Details page, Patch policies
Overview
Ignoring a title does not block a patch instantly. It changes what the device reports as needing a patch, and that new status only reaches your policies after the device runs a scan. If a policy executes before the device has scanned, the device still reports the title as patchable and the policy installs it — the ignore was set, but it hadn't been registered yet.
Resolution
- Confirm the ignore was applied at the right scope:
- Ignoring from a device's Device Details page affects only that device. To exclude a title everywhere, ignore it from the Software page, which acts across the matching devices. See Configuring Software on a Device.
- Run a device scan before the next policy execution:
- This is the most common cause. The ignored status must be registered by a scan before a policy runs, or the policy will still patch the title. Scan the device (or wait for its next scheduled scan) and confirm the title now shows as Ignored.
- If ignores routinely register too late, tighten the scan interval so status changes are picked up before policies run:
- For a durable exclusion rather than a one-off ignore, choose the method that fits:
- Ignore — immediate, best for one-off or temporary blocks on specific devices.
- A Patch Only policy scoped so it simply does not target the title (for example, a Patch All Except configuration).
- The Block List for Windows patches.
- All three are covered in Prevent Specific Software From Updating in Automox.
- Re-verify after the next scan and policy run to confirm the title is no longer being patched.
Notes
- Ignore takes effect immediately in the console, but is only reflected in policy targeting after the device's next scan — the gap between the two is where unexpected patching happens.
- Removing the ignore reverses this the same way: the title becomes patchable again only after the next scan.
- For background on how scans and check-ins differ, see What is a Check-In vs. Device Scan?.
