From the Manage → Remediations page, you can organize vulnerabilities into Automox tasks.
Download a CSV-formatted Vulnerability Report
Follow the instructions in Exporting Vulnerability Scanner Reports to download a CSV-formatted vulnerability report from your third-party vulnerability scanner.
Viewing Remediations
Click the Manage tab and select Remediations → Manual.
Uploading a Vulnerability Report to Create Tasks
You can upload a CSV-formatted vulnerability report from a variety of different CSV providers and start adding tasks.
Note: The maximum file size for CSV uploads is 20,000 rows.
Note: If you are accessing the Remediations page for the first time, you may see the options manual import or partner integration. Select the Get Started button for manual import and follow the steps here.
From the Remediations → Manual tab, click Import.
Select the CSV provider format for the report that you want to upload.
Note: The format required for the report is listed in the Expected Format field. Refer to that to ensure that the uploaded file meets the requirements (see also Exporting Vulnerability Scanner Reports).Click Upload File and select the CSV file that was downloaded from the vulnerability scanner.
If Automox determines the size of the file is acceptable, a confirmation shows that the file is accepted without errors and prompts you to click Next.
A message then shows that it is processing the CSV. Click Finish.
Syncing the Imported Report
The mapping process is asynchronous and it takes time to discover hostnames and any CVEs that they are impacted by. A sync is complete once it shows as Ready. Each CSV file has its own row and when the file completes processing it is highlighted.
Table Column | Description |
Name | Name of the CSV file that was uploaded |
CSV Provider | Indicates the CSV provider source |
Uploaded By | Email address of the user who uploaded the file |
Status | Possible values:
Patchable Vulnerabilities | Number of vulnerabilities and affected devices that can be remediated by Automox |
Unmatched Vulnerabilities | Number of vulnerabilities and affected devices in your environment |
Unknown Devices | Number of devices that do not currently exist in your Automox organization |
Updated | The date the file was uploaded |
Actions | Options:
Remediating Vulnerabilities
The Remediation Details page provides a detailed view of vulnerabilities imported manually using Vulnerability Sync or automatically from Rapid7 using Automated Vulnerability Remediation. This page reduces time to remediation, and provides greater visibility into vulnerabilities affecting your environment.
There are three tabs on this page: Patchable Vulnerabilities, Unmatched Vulnerabilities, and Unknown Devices.
The Patchable Vulnerabilities tab lists vulnerabilities and affected devices that can be remediated by Automox. Click the Remediate button to patch all of the devices for a specific vulnerability.
Device | Name of the device |
Hostname | Permanent device name |
Private IP | IP address of the device |
Remediation Status | Status of the vulnerability remediation for the specific device |
After you click Remediate, the remediation status of each device updates as the policies are run, along with a filterable donut display for all results.
Remediation statuses include:
Not Started
In Progress
Success
Failed
Timed Out
Canceled
The Unmatched Vulnerabilities tab also lists vulnerabilities and affected devices in your environment. These vulnerabilities require you to specify a Worklet Policy in order to remediate the affected devices. Click the Remediate With Worklet button to view your existing worklet policies to remediate with.
Worklet Name | Name of the Worklet Policy |
OS | Supported operating systems by the policy |
Notes | Clicking this icon expands a section with notes about the policy |
Details | Clicking this link opens the “Edit Worklet” page for this policy in a new tab |
Unknown Devices
The Unknown Devices tab lists devices that do not currently exist in your Automox organization. This information can be used to identify gaps in your environment where the Automox agent is not already installed. The list of device hostnames can be exported and used in a tool like Automox Agent Deployer, which supports automatic deployment to CrowdStrike-managed devices.
Device | Hostname of the unknown device |
Related Topics:
