Need to reset your Automox Customer Portal password?
To reset your password, click the Sign in button at the top right corner of the Customer Portal:
Click the 'Forgot my password' button on the sign in window.
You will be prompted for your email that you use to access the Customer Portal. After this is entered, an email with instructions will be sent to that email.
You will get an email similar to this to finalize your password reset.
If you have any further trouble, please contact support at support@automox.com
