From the Settings → Keys tab, you can view a zone’s agent access key and all associated API keys.
Keep API Keys Secure!
API keys should be kept secure and not shared to prevent unforeseen changes or potential security issues. Never email or write down your API key.
Viewing Keys
Select the Settings → Keys tab to view the agent access key and the API keys.
Account ID
This is the UUID for the account. (Only global or zone administrators can see this ID)
To copy the agent access key, click the Copy button (clipboard) to the right of the field.
Agent Access Key
The agent access key is used to add devices to your Automox account.
API Key
The API key is used to access the Automox API.
Note: API keys are not automatically generated for new users or new zones. See Adding API Keys.
To view an API key, click the Show button to the right of the hidden characters. The key will automatically hide again after 10 seconds.
To copy the API key, click the Copy button (clipboard) to the right of the field. It is automatically decrypted.
Note: When you use API keys, take care to keep them secure. Follow best practices such as these:
Do not embed API keys directly in code.
Do not store API keys in files inside your application’s source tree.
Managing API Keys
Your user account role determines what API key management functionality is available to your account. There are four types of user roles.
Zone administrators can view and manage all organizational API keys for the zone that they have permissions to.
Zone operators (formerly patch administrators) can only view and manage API keys created with their user account.
Patch operators can only view and manage API keys created with their user account.
Billing administrators can only view and manage API keys created with their user account.
Read Only users can only view and manage API keys created with their user account.
(See User Accounts for more information about role-based account controls.)
Global and Zone Administrator privileges
View all of the zone’s API keys on the Settings → Keys page of the console.
Disable and delete all of the zone’s API keys on the Settings → Keys page of the console.
Disable and delete all of the zone's API keys through the API.
All other administrator and user privileges
Zone operators, billing administrators and read-only users have the following permissions:
They can view only the API keys that were created by their user login on the Settings page of the console .
They can disable and delete the API keys that were created by their user login on the Settings page of the console.
They can disable and delete the API keys that were created by their user login through the API.
All users
Users can sort on the user column.
Users can only add keys for their own account.
Adding API Keys
You can add up to 10 unique API keys to a user account.
From the Settings → Keys page, click Add.
Enter the unique name of the API key. You will see an error message if you enter a name that already exists.
(Optionally) You can select an expiration date for the API key.
Click Create.
Disabling API Keys
You can disable API keys that are from your own account.
Note: Only global and zone administrators can disable API keys for all users.
Select the Settings → Keys tab to view the list of API keys.
To find the API key that you want to disable, sort by the Name or User column. Show or hide the API key, as needed. If you don’t see the API key you want, select from the next page at the bottom.
To disable the API key, turn off the toggle switch under Enabled.
Note: When an API key is disabled, the key is rejected and returns an error. It is possible to re-enable an API key.
Deleting API Keys
You can delete API keys that are from your own account.
Note: Only global and zone administrators can delete API keys for all users.
You can sort by the Name or User column to find the API key that you want to delete. Show or hide the API key, as needed. If you don’t see the API key you want, select from the next page at the bottom.
To delete the API key, click Delete in the manage column.
Note: When an API key is deleted, the key is rejected and returns an error.
Managing Columns
Use the Column drop-down menu to select which table columns you want to include or exclude from view.
Select or clear any checkboxes to control the API Keys page view.
You can change the order of the columns by dragging the - next to the column names to the desired position.
