The recommended deployment of the Automox agent consists of 3 configurations:
Create or Modify Existing Notification Profile
macOS Catalina supports notification configuration profiles to ensure delivery of Automox notifications.
If no notification payload currently exists, create a new profile with Custom Settings with the following content to allow all Automox and Microsoft Office notification to run:
<dict> <key>NotificationSettings</key> <array> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.automox.automox-notifier</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.Word</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.Excel</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.Powerpoint</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.Outlook</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.onenote.mac</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.OneDrive</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>1</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.OneDrive-mac</string> <key>CriticalAlertEnabled</key> <false/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> <dict> <key>AlertType</key> <integer>2</integer> <key>BadgesEnabled</key> <true/> <key>BundleIdentifier</key> <string>com.microsoft.autoupdate.fba</string> <key>CriticalAlertEnabled</key> <true/> <key>GroupingType</key> <integer>0</integer> <key>NotificationsEnabled</key> <true/> <key>ShowInLockScreen</key> <true/> <key>ShowInNotificationCenter</key> <true/> <key>SoundsEnabled</key> <true/> </dict> </array> <key>PayloadDescription</key> <string>Configures notifications</string> <key>PayloadDisplayName</key> <string>Configures notifications</string> <key>PayloadIdentifier</key> <string>com.apple.notificationsettings.AE35A3DC-56BC-48EB-8C4D-F4C5AE4D1C5C</string> <key>PayloadType</key> <string>com.apple.notificationsettings</string> <key>PayloadUUID</key> <string>AE35A3DC-56BC-48EB-8C4D-F4C5AE4D1C5C</string> <key>PayloadVersion</key> <integer>1</integer> </dict>
If you have an existing Notifications profile (macOS only supports a single notifications profiles), add the previous content in your existing NotificationSettings array.
Create an Automox Privacy Preferences Profile
Automox leverages Microsoft's AutoUpdate Tool to handle Microsoft Office updates. To ensure the Automox agent is also granted access to this, you must create a Privacy Preferences Profile.
Devices > Profiles and Resources > Profiles
Add Profile
Apple macOS
Device Profile
Select Privacy Preferences
Add App
Identifier: /usr/local/bin/amagent
Identifier Type: Path
Code Requirement: identifier "com.automox.agent" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = DAEQ58A4ES
Static Code Validation: Off
Apple Events: Allow
Receiver Identifier: com.microsoft.autoupdate2
Receiver Identifier Type: Bundle ID
Receiver Code Requirement: identifier "com.microsoft.autoupdate2" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = UBF8T346G9
Deploy the Automox Agent as a Native Application
Install the VMware AirWatch Admin Assistant https://docs.vmware.com/en/VMware-Workspace-ONE-UEM/1904/Software_Distribution/GUID-AWT-ADMINASSIST.html
Download the latest Automox Agent
Pull the Automox Agent pkg file into the Admin Assistant
Open the generated plist file
Find the
display_name
key and remove the trailing version characters.
(Airwatch does not support dashes-
in display names)Before:
After:Save file.
Add a Native Application to Airwatch
Upload the Automox pkg installer file
Upload the plist as the "Metadata File"
For automated installations, add the following code to the "Post Install Script"
#!/bin/bash /usr/local/bin/amagent --setkey "ENTER_AUTOMOX_ACCESS_KEY_HERE" /usr/local/bin/amagent --setgrp "Default Group/ENTER_GROUP_NAME_HERE" launchctl kickstart -k system/com.automox.agent
