This manual process for deploying an emergency patch will decrease the time it takes to ensure your legacy machines are operating at lower risk to exploit.
Note: Automox cannot fully update Windows XP versions due to the lack of support for XP updates by Windows Update. Automox can manage software installation and patching, as well as configuration and security settings.
There are 2 minimum requirements that can allow Automox to run on Windows XP:
Microsoft .NET Framework 3.5 or later
Windows PowerShell 2.0 or later
Windows XP Required Prerequisites
Install .NET Framework 3.5 (or later)
https://www.microsoft.com/en-us/download/details.aspx?id=21
Install PowerShell 2.0 via Windows Management Framework (.NET required first)
https://www.microsoft.com/en-us/download/details.aspx?id=16818
Install Automox (with legacy Installer)
https://console.automox.com/Automox_Legacy_Installer-latest.msi
(Note: GetSystemDetail scan command WILL NOT work, so there are no hardware details and the compatibility check will always show “Not Compatible”.)
Download the appropriate Windows Edition patch from the MS Catalog.
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4500331
Worklet Instructions
In the Automox console, from the Manage → System Management page, click Create Policy.
Click Worklet.
Click Next.
On the Create Worklet page, name the worklet.
Enter the Evaluation and Remediation scripts as shown in the Example. Evaluation is optional if you’re going to execute manually.
Upload the KB file to the policy.
Click Create Policy.
Associate the worklet to a group or multiple groups and click Associate.
Click Save Policy.
From the Polices page, execute the worklet by clicking the Actions → Run Policy.
Within minutes, the patch is installed on your XP devices.
Example
For the Evaluation code block
### Evaluation #Define KB Number and check for presence $kbID = 'KB4500331' $installed = Get-Hotfix -Id $kbID -ErrorAction SilentlyContinue if ( $installed ) { #Compliant, so Exit 0 as success Exit 0 } else { #Non-Compliant, so Exit 1 as failure Exit 1 }
For Remediation code block
### Remediation #Enter the name of the file you uploaded $fileName = "windowsxp-kb4500331-x86.exe" #Launch the installer file and capture exit code to determin success $installer = Start-Process -FilePath $fileName -ArgumentList "/quiet /passive /norestart" -Wait -PassThru #Evaluate Exit Code for Success 0,1641,3010 are all considered successful if ( $installer.ExitCode -in @('0','1641', '3010')) { Exit 0 } else { Exit 1 }
