When a meeting is in progress for versions of Zoom 4.5.2.3370.0908 and earlier, in order for the client to be patched, any meeting in progress will be interrupted. We suggest updating Zoom to the latest version, then future patches will allow any conferencing to happen without interruptions.
You can patch to the latest version of Zoom from the Software page. Enter zoom in the search field. When a version of Zoom listed has a patch available, it will show in the Impacted column. If you are not using the client, you can immediately patch by clicking Actions → Patch Now. Confirm your selection.
You can also patch to the latest version of Zoom from the Device Details page. In the Software section, search for Zoom and, if you are not using the client for a meeting, select Patch Now from the list of actions.
For further questions, please contact support@automox.com
