Agent Firewall Allowlisting Rules
Refer to this document for a list of addresses to optimize Automox agent functionality as well as addresses needed to patch Microsoft OS versions from Windows update.
Regarding Ad Blockers - We recommended disabling ad blockers (such as uBlock Origin) for the Automox Console, as ad blockers can adversely impact the functionality of the product.
Network and firewall requirements for running the Automox agent
If your organization has egress filtering on the firewall, you will need to allow access to the following hostnames / IP addresses for the Automox agent to communicate with the cloud platform. All agent communications take place over port 443 (https).
Agent access to content uploaded for use with Worklets and Required Software Policies:
  • automox-policy-files.s3.us-west-2.amazonaws.com
Note: The platform-IP addresses are subject to change. Add the hostnames to your list of trusted sites, if possible, or regularly check for the latest IPs assigned to the platform.
Recommended approach using URL
Domain
Protocol(s)
Direction
Ports
*.automox.com
TCP
Outbound
443
*.digicert.com
TCP
Outbound
80
*.digicertcdn.com
TCP
Outbound
80
app.launchdarkly.com
TCP
Outbound
443
clientstream.launchdarkly.com
TCP
Outbound
443
events.launchdarkly.com
TCP
Outbound
443
Additional recommendations for Automox Remote Control
Domain
Protocol(s)
Direction
Ports
d1ovafk2iqpmhd.cloudfront.net/
TCP, UDP
Outbound
80
*.rc.automox.net
TCP, UDP
Outbound
7844
region1.v2.argotunnel.com
TCP, UDP
Outbound
7844
region2.v2.argotunnel.com
TCP, UDP
Outbound
7844
cftunnel.com
TCP, UDP
Outbound
7844
h2.cftunnel.com
TCP, UDP
Outbound
7844
quic.cftunnel.com
TCP, UDP
Outbound
7844
api.cloudflare.com
TCP, UDP
Outbound
443
update.cloudflare.com
TCP, UDP
Outbound
443
pqtunnels.cloudflareresearch.com
TCP, UDP
Outbound
443
  • Alternative approach using IP addresses:
    • Check for current IP addresses by running the following command: nslookup api.automox.com
Recommended Approach Using Specific URLs
In addition to the URLs shown above, the following URLs should be added to your allowlist, particularly if your firewall does not support the use of wildcards:
Domain
Protocol(s)
Direction
Ports
api.automox.com
TCP
Outbound
443
console.automox.com
TCP
Outbound
443
ct.automox.com
TCP
Outbound
443
rc.automox.com
TCP, UDP
Outbound
443
storage-cdn.prod.automox.com
TCP
Outbound
443
worklet-signing.prod.automox.com
TCP
Outbound
443
installation-reporting-service.prod.automox.com
TCP
Outbound
443
llm.automox.com
TCP
Outbound
443
downloadexport.automox.com
TCP
Outbound
443
policyreport.automox.com
TCP
Outbound
443
download-export-cdn.prod.automox.com
TCP
Outbound
443
rtt.automox.com
TCP
Outbound
443
agent-content-cdn.automox.com
TCP
Outbound
443
Proxy and Firewall Considerations
See Windows Update troubleshooting: Issues related to HTTP/Proxy
You might choose to apply a rule to permit HTTP RANGE requests for the following URLs:
*.download.windowsupdate.com
*.dl.delivery.mp.microsoft.com
*.delivery.mp.microsoft.com
Firewall
See Windows Update troubleshooting: Device cannot access update files
Protocol
Endpoint URL
TLS 1.2
*.prod.do.dsp.mp.microsoft.com
HTTP
emdl.ws.microsoft.com
HTTP
HTTP
*.windowsupdate.com
HTTPS
TLS 1.2
*.update.microsoft.com
TLS 1.2
tsfe.trafficshaping.dsp.mp.microsoft.com
Note: Make sure to not use HTTPS for those endpoints that specify HTTP, and vice versa. The connection will fail.
Note: When leveraging split-tunneling with a VPN, make sure to include these endpoints in your list of sites with direct access to the internet.
The Automox Agent Notifier must be added to the Windows Defender Firewall Allowed Applications.
Microsoft Windows 10 Connection Points
Microsoft provides a complete list of connection points per Windows 10 feature version. Here is a link to the connection point document for Windows 10 version 20H2 (refer to the links on the left for other feature versions).
https://docs.microsoft.com/en-us/windows/privacy/manage-windows-20h2-endpoints
See Use Apple products on enterprise networks.
1 out of 2 found this helpful
