The Worklet Catalog allows you to immediately use a verified Worklet for your purposes. You can also create a new policy based on an existing worklet.
You must have the required administrative permissions to create a Worklet. See Roles and Permissions.
Accessing the Worklet Catalog
You can access the catalog from the Manage → Worklet Catalog page.
From the console, select the Manage tab and then select Worklet Catalog from the drop-down menu
Worklet Catalog
Worklet Catalog Table |
Description |
Worklet Name |
Name assigned by Automox |
Verified |
Verified indicates that the Worklet is internally tested and free of known security or performance vulnerabilities. This is no guarantee for desired results in your particular environment. |
OS |
This is the OS type that the worklet is intended for. |
Category |
Worklets are organized into categories, such as: Software, Utility, Security, among others. |
Creator |
Automox team member who created the worklet |
Last Updated |
Time and date when the worklet was last updated |
Actions |
Possible actions:
Search the Worklet Catalog
From the Workout Catalog page, you can use the search bar to search for a worklet by a variety of terms. You can enter partial names and as many search items as you want. For example:
Name
Description
Operating system
Keyword
Search by Name values supports fuzzy search, which takes misspellings into consideration. Other search terms (such as description, OS, or keyword) use a wildcard match.
Click the column heading to sort by that type of data. You can now also turn off a sort when a column is sorted a third time, which reverts results back to sorted by relevancy.
The results include any matching data, or close to matching data. Search results are returned by relevance to the search term.
You can also refer to our website to search through the growing list of worklets: https://www.automox.com/worklets
Viewing Details
There are two ways to view the details of a verified Automox worklet.
Click the Worklet Name in the table. The details view opens.
You can also open the Actions menu for the worklet you want to view details for. Click View Details.
In the Worklet Details window, select Code Preview to open the Evaluation and Remediation Code details for the selected worklet.
You can scroll through the code to view the details.
To edit the code presented in a worklet from the catalog, you must first add it to a policy. Click Create Policy.
The Create Worklet page opens and you can make the desired changes, such as:
configure device targeting
edit code
set a schedule
configure user notifications
To contact Automox Support for further assistance, submit a request in the customer portal.
