Manually testing installation notifications and evaluation code
When testing a policy for your environment, the following is very important. If there is an installation notification that needs to be tested, the policy should not be executed manually.
When a policy is executed manually anywhere within the console, the installation process is ignored and the remediation immediately executes. This is applicable for all policy types.
Therefore, if there is an installation notification or an evaluation portion to a worklet, it must be scheduled in order for testing to be accurate.
