Assigning a device to a group with Install-AxAgentMSI.ps1
When using the Install-AxAgentMSI.ps1 script from this article Automox Agent Installation Overview, you'll notice that you can use this example to assign a Parent Group:
.EXAMPLE
Run this script file with at least an AccessKey specified
Install-AxAgentMsi.ps1 -AccessKey xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Optionally include a Group and Parent Group Name as needed
Install-AxAgentMsi.ps1 -AccessKey xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx -GroupName "My Group Name" -ParentGroupName "My Parent Group Name"
Take note of the following:
If the parent group is also the child member of another group, then you do not need to include the parent's parent.
Example of incorrect assignment:
Install-AxAgentMsi.ps1 -AccessKey xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx -GroupName "My Group Name" -ParentGroupName "My Parent's Parent Group Name/My Parent Group Name"
It is better to just use the immediate parent groups name for the Parent Group as shown in the first example.
