The Policy Results report is a report of the most recent policy runs in a zone. You can see the success rates and understand which devices had failures so that you can take action.
See also Creating Reports and Data Extracts
Policy Results Overview
The policy results report lists only on the most recent run (within the last 30 days) for all patch policies in your zone. Results are shown in either a bar chart or a table.
Note: You can export a CSV file of the complete results for a specific timestamp. There is currently no option to share the report.
Policy Results Bar Chart
From the Reports page, click View for the Policy Results Report. The default view of the policy results report is the bar chart format.
This bar chart represent the results of the most resent policy runs. Refer to the legend for a description of the three colored sections.
You can do the following:
Click an individual bar to open the details page
From the Actions menu you can: Run Policy, View Policy Configuration, View Result Details, or View Activity Log
Hover over a bar to view the details about the individual policy run
Sort the list by Policy Name, Last Run Time, Total Devices, Success Count, Pending Count, or Failed Count
Search for a specific policy by policy name. This allows for partial matches.
Policy Results Table
You can view the policy results report in the table format. To switch between the bar chart and the table, select from the report toggle at the top of the chart. Use the search field to narrow down the results.
Column name | Description |
Policy Name | Name of the policy included in this report |
Last Run Time | Time of the most recent policy run |
Type | The type of policy for the report |
Total Devices | Number of devices associated with the policy |
Success Count | Number of devices that have been successfully updated under this policy run |
Pending Count | Number of devices that show the policy run has started but is not yet completed |
Failed Count | Number of devices with unsuccessful policy runs |
Summary | Quick summary overview of the latest run for a policy |
Actions | Select from the following options:
Sorting the results of the Policy Results table
You can sort the contents of this report.
Click the up or down arrows in the column headings to sort the contents of the table.
Policy Result Details
You can view the details for the last run of an individual policy.
Policy Run Results table
Activity Log
Results Summary
To view the details of an individual policy run, from the Policy Results chart or table, click the name of the policy. The policy run results table is shown.
Policy Run Results
Device | Name of the device that is in the policy |
Result | Possible outcomes: Success, Pending, Failed |
Event Time | Time and date for when the policy was run |
Actions |
Results Summary
The results summary is a quick visual interactive bar chart of the results for the selected policy run.
Activity Log
To view the activity log for the specific policy run, click the Activity Log tab from the policy results details page. This activity log is specific for the selected policy. See also Creating Reports → Activity Log.
